Sketchup 2013 (make)
BerichtGeplaatst: 19 aug 2013, 20:47
Introducing SketchUp 2013
Sinds enige tijd weer een nieuwe versie van Sketchup, de 2013 versie, ook wel Make genoemd. Make is de free versie. Ook de Pro bestaat nog, kost ca. 475 euro.
Onderstaand de nieuwe dingen in Sketchup 2013, welke, voorlopig alleen nog in het Engels beschikbaar is.
For SketchUp 2013, we focused on two things: making LayOut even more powerful, and building an ecosystem that makes it easier for millions of SketchUp modelers to find and use the plugins, add-ons and extensions they need. Upgrade a Pro license now.
Introducing Extension Warehouse
What if adding new extensions to SketchUp was as easy as installing an app on your smartphone? In 2013, we’ve made it dead simple to turn SketchUp into exactly what you need it to be. Need a special tool? There’s an excellent chance someone’s already built it. Now you can research, download and install extensions without ever having to leave SketchUp. Every useful extension in one place—that’s the all-new Extension Warehouse.
Pattern Fills
Drawing a sectional view? Now you can fill shapes in LayOut with hatching and other patterns. Choose from a large library of standards—construction materials, geometric tiles, dot screens—or create your own favorites. Patterns can be rotated, scaled or used as-is. You can even combine Pattern Fills with solid colors to create an endless number of variations.
Copy Array
You know how SketchUp lets you easily create multiple copies of an object with your keyboard? Those are called arrays, and now LayOut lets you make them, too. Move a copy, type how many copies you want, type the letter ‘x’ and Enter. Presto! Presto! Presto! Presto! Presto! Copying is fun.
Speedier Vector Rendering
When you need to print a drawing really big, sometimes it’s helpful to vector-render your SketchUp model views. Doing so makes lines look smooth and reduces wait times for all but the most complex models. In the latest version of LayOut, vector rendering is faster than it’s ever been.
Faster Screen Redraw
Every time you zoom, pan or move an entity on the page, LayOut has to re-draw the picture you see on your screen. For this version, we massaged the code so there’s a noticeable improvement in the speed at which this happens. LayOut should feel snappier, especially as your document gets more complex.
Numbered Pages in the Pages panel
Another small but incredibly useful tweak: LayOut’s Pages panel now displays page numbers, which makes it easier to print and export portions of your document.
Curved Label Leader Lines
Creating a jauntily curved callout line for a label used to be a five-step, two-handed operation:
Click. Click. Tool switch. Double-click. Click-drag-with-a-modifier-key.
In the latest version of LayOut, curving a label line goes like this:
Click-drag.
Isn’t progress something?
Dashes in Dimensions
Ask the guy with the 86 foot ceiling if readable dimensions are important. It’s a little thing, but we added dashes to LayOut’s dimension labels to make them easier to read.
Smarter Toolbars in Windows
It used to be that the toolbars for all of your delicious plugins would move around your screen between SketchUp sessions. We heard that drove you crazy, so we re-engineered our Windows UI to make things a whole lot better. In 2013, you can even drag native tool icons between toolbars. Make SketchUp look the way you want it to.
Video Export
Exporting high-quality animations from SketchUp 2013 is easier than ever. Using the default settings yields HD videos at 720p, encoded in any of the three most popular, modern formats: H.264, AVI and WebM. Picture quality is much better, and file sizes are smaller as well.
Zoom In More
We increased LayOut’s maximum zoom capability by a factor of ten, from 1000% to 10,000%. At that magnification level, your sofa would be the size of Jupiter. Or thereabouts.
Re: Sketchup 2013 (make)
BerichtGeplaatst: 02 okt 2013, 14:35
Woonplaats: Harderwijk
Ben benieuwd, ga hem er vanavond op zetten..
BerichtGeplaatst: 10 okt 2013, 12:54
Nou....bevalt prima!! Vooral Lay-out is er op vooruit gegaan..
BerichtGeplaatst: 30 okt 2013, 14:56
Sketchup make is niet gratis. Je mag er 8 uur mee spelen.
BerichtGeplaatst: 31 okt 2013, 18:45
SketchUp Make is gratis. SketchUp 2013 niet. Je mag er 8 uur mee aan de slag. Daarna moet je het met SketchUp Make (en zonder Layout) doen ..... of een licensie kopen.
